Arvandor593
Aug 06, 2022Aspirant
AC1200 Dual Band Range Extenders blocking direct connection
I have installed a pair of AC1200 dual band wifi range extenders. But they seem to be preventing my desktop PC from directly connecting to my broadband modem. I can connect to the extenders, and whe...
Aug 06, 2022Guru - Experienced User
What actual extenders do you have? AC1200 is a speed.
What modem/gateway are the extenders connected to?
What method of setup did you use? WPS or the installation assistant?
Arvandor593
They are both EX6110 extenders. I've given them separate SSIDs.
They're connected to a Virgin Hub 5.
They were connected via WPS.
