PriorLane's avatar
PriorLane
AC1200 Dual Band WiFi Extender [can I reconfigure in a different town]
  • additude's avatar
    additude
    Apr 30, 2019
    You should be able to reconfigure the extender when you take it to a new LAN location.
    I think that if both your locations employ WPS then it should be as simple as using WPS at each location.
    But yes, you should be able to take the extender from one LAN location and move the extender to another LAN location and after reconfiguring the extender. then it will operate on the new LAN.
    If you do not reconfigure the extender, then it will not operate properly at the new LAN location.
