Abro
May 02, 2020Follower
Ac1200 Dual Band Wifi Extender Ex6150 will not accept my wifi password.
So, I have completed the steps of the WPS set up. My WiFi range extender has the green light displayed which indicates a connection to my router, however when I try to connect to the wifi extender us...
May 03, 2020Guru - Experienced User
So range extenders can be setup via wps or using the installation wizard. not all device makers code wps the same so it can create issues. If wps doesn't work, factory reset the extender and re-run setup using the installation wizard.
factory reset by pushing and holding reset while its powered on for 7-15 seconds.
the installation wizard video walk through is the 2nd video on the support site.
