Anfield
Nov 18, 2019Aspirant
AC1200 Dual Band WiFi Range Extender
When router is on the extender shows Green. When the device is on the extender on the LINK LED is blank. In the device settings the existing WiFi name is connected but the _ 2GEXT and _5GEXT seem ...
Anfield
Nov 19, 2019Aspirant
My last request for help was returned as undelivered for some reason.
My question was an issue on AC1200 Dual Band WiFi Range Extender Model EX6120.
When the device is on the DEVICE LINK LED light is blank whereas when the router is on the ROUTER LINK LED shows Green.
In settings the MyNetworkName is connected as it was before the extender was installed with the Router password.
After the installation MyNetworkName_2GEXT and MyNetworkName_5GEXT are added.
I do not know if they are connected but if I highlight either then they require a password. They also have the stronger signal.
Q: Do I need to add passwords to these two?
Q: Why is there no light on Device Link Led
Q: Are the two questions connected?
Page 7 on the booklet says Use the same WiFi password that you use for your WiFi router is not clear that it means for all three.
Anfield
Nov 19, 2019Guru - Experienced User
Anfield wrote:My last request for help was returned as undelivered for some reason.My question was an issue on AC1200 Dual Band WiFi Range Extender Model EX6120.When the device is on the DEVICE LINK LED light is blank whereas when the router is on the ROUTER LINK LED shows Green.In settings the MyNetworkName is connected as it was before the extender was installed with the Router password.After the installation MyNetworkName_2GEXT and MyNetworkName_5GEXT are added.I do not know if they are connected but if I highlight either then they require a password. They also have the stronger signal.Q: Do I need to add passwords to these two?---if you setup wps it should be the same password as the router's wifi. If you manually set it up, it'll be whatever you set if you set a password.Q: Why is there no light on Device Link Led--because nothing is connected to the extender. it lights up when something is connected.Q: Are the two questions connected?---a littlePage 7 on the booklet says Use the same WiFi password that you use for your WiFi router is not clear that it means for all three.----All 3? it copies the wifi password whenever you setup via wps. for all both 2.4ghz and 5ghz ssid's.Anfield
An easy way to check to see if it setup properly is to connect a pc/laptop to the extenders ethernet port. If the internet works while connected via ethernet, it should be setup properly. Plus if you didn't know your ssid password, you can log into the extender this route and get the ssid and password via the ethernet connection.
