123martinh
Jan 10, 2022Follower
AC1200 Dual Band WiFi Range Extender
I am posting a solved problem to help others: On installing this new Dual Band Wifi Extender using WPS the _2GEXT configuration rejected the router password. The (same) password worked and connecte...
Jan 10, 2022Guru - Experienced User
Fairly common to use the installation assistant and not WPS for setup. Sadly, a lot of isp supplied routers don't code wps properly and it causes issues.
But glad to hear you got it working!
thanks for posting this
