28dacarr
Jun 01, 2024Aspirant
AC1200 dual band WiFi range extender
Spectrum router doesn't have WPS button so don't know how to set up extender? I previously set it up to AX3000 tp-link router Tried the altetnative instructions but was not successful logging into NET...
28dacarr
Did factory reset. Got on Netgear_ext I have Spectrum router which when I enter suggested site. The router info comes up. When enter .net site It says I'm not connected to extender WiFi.
Jun 03, 2024Guru - Experienced User
go through the connection process on the netgear. Once that is completed, you can log into the spectrum router and find the IP address for the extender. Use the IP address to access it
