csango
Sep 23, 2021Aspirant
AC1200 Dual Band WiFi Range Extender(EX6120) Device Lights turns amber/red every now and then
AC1200 Dual Band WiFi Range Extender(EX6120)Device light turns amber evey now and then and then the data throughput drops as expected then turns back again, the Wifi light is always solid Green means...
csango
plemansHere are the details
Serial # is 4D6C0875A0BED, I have updated firmware 1.0.0.58
Its connected to Nokia Wireless Router given by my ISP and the plan I am on is 100+ Mbps plan & other devices/Extender get at lest 40+ Mbps speeds
Distance between main router and Extender is around 30 Feet. (max) No walls no interference just straight sight/air between two devices.
The Distance from Extended and laptop/workstation is 8 Feet line of sight straight and there is one wooden door of 2 inches thickness (door is closed as its my study room/office)
I used both 2.4 & 5 GHz both drop off device connections regualrly however 2.4 is more sensitive YES.
Hope this helps
csango
Sorry a correction on firmware its 1.0.0.64
