CudaDude's avatar
CudaDude
Follower
Feb 28, 2018
AC1200 EX6120 Dual Band Range Extender Internet only on 5ghz
I purchased 2 of the AC1200 Dual Band Range Extenders Model 6120. The problem I have with both of them is that I do not have internet access on the 2.4ghz extended network. There are 2 ways to setup the device, WPS and manually through mywifiext.net. I tried WPS on one of them and manual setup on the other, both with the same result. In the end I can only connect to the 5ghz extended network. When I try and connect to the 2.4 ghz extended network it says no internet access. In the mywifiext setup both extended networks show connected and broadcasting. I have upgraded the firmware on both devices, factory reset both devices, and reset them both up manually one at a time, with only one plugged in at a time. My router firmware is up to date and can connect devices to my regular 2.4 and 5ghz networks without issue. Thanks for the help!
1 Reply
  • Hi CudaDude,
                              Try to modify wireless channel on 2.4GHz of your router and check if it works.
