mcdermottmp's avatar
mcdermottmp
Follower
Sep 17, 2020
AC1200 EX6150v2
Working fine fr months then suddenly the router LED has no light. All other lights are green including the Client link light. Was using for Ring security now the devices will not see the network. Rest both my router and the extender multiple times. any help would be appreciated. It is about 6 months old.
  • plemans's avatar
    what router is it connecting to?
    What firmware is on it?
    have you tried reinstalling the extender using the installation assistant?
  • I actually have had the same issue, mcdermottmp. Were you able to find a solution?
    • plemans's avatar
      kg87 If you start your own post, we'd be happy to help.
