DeeBeeEff's avatar
DeeBeeEff
AC1200 EX6200v2 Maxed out. Where should I go from here?
Hello, I currently have an AC1200 in AP mode connected to my Uverse Pace 5268AC modem. Between the two of them, there are roughly 49 WiFi devices (mostly WiFi light switches and outlets - 23 connect...
  • plemans's avatar
    Dec 30, 2019
    A simple AP isn't going to add a bunch of latency. If you're running it in extender mode, it will. But if its in AP mode, you should be fine.
    That's a lot of 2.4ghz devices. :(  shouldn't be a huge issue if most are IoT devices but if you're running streamers off 2.4ghz, that might not work the best.
    And that's not much upload speed for all your devices. If blink is recommending at least 2mbps/camera and you've got 2 cameras, 80% of your upload bandwidth is being used by 2 cameras.
    Only other thing I'd look at would be the camera's themselves. I've read a couple reviews of the blink cameras and the one's (few) that talk about wifi, speak to the same spotty/weak coverage you talked about initially. Not sure if they had to dial back the wifi module to get their advertised lifespan or whats going on.
