MorningDG
May 31, 2019Follower
AC1200 extender, router password not recognised
Extender setup and connected to router. A reset also performed. When you enter the password it doesnt recognise it.
May 31, 2019Guru - Experienced User
the A6150 is a usb wireless device. What is your actual model number for your extender?
You say you've tried a reset on the device, how do you know it reset correctly? While holding the reset, did you hold it until the lights change/blink?
What password is failing? the password to access the wifi or the password to login to the device?
