Peachyyyy
Dec 18, 2019Aspirant
Ac1200 lights keep blinking and no internet access
So I just bought the wifi extender to boost my connection to my Xbox across the house. I got it connected and set up and it told me no internet access. Okay, I'll just move it closer to the router i...
Dec 19, 2019Guru - Experienced User
What router are you connecting back to? A extender can only be as good as the router that its connecting to as its relying on its connection. If you have a bad/poor router or the wifi has a lot of intereference, its going to show a poor connection.
So:
1. router your connecting to?
2. Firmare on the extender?
3. What are the interior walls of you house? This is kind of key as certain materials do great jobs of blocking wifi signals.
4. how big is your home?
5. Did you do the setup via wps or using the smart connect wizard? some device manufacturers wps setup mechanisms don't work that well between different device makers.
Peachyyyy
Dec 19, 2019Aspirant
The router I'm connecting to is something with Att u-verse.
Firmare on the extender, I haven't looked at.
the interior walls are very thin I don't know exactly.
It's a 3 bedroom home so not huge. Just big enough that the wifi drops to 2 bars on our side of the house.
I did both. Originally just plugged it in and set it up with my phone, wasn't working so I factory reset it and tried wps.
Still didn't work.
I even plugged it in with an Ethernet cable and it told me it had a weak signal.
My confusion is that it does connect but only for a good 2 minutes before it seems to drop the signal and the Netgear logo starts blinking.
Still didn't work.
- plemansDec 19, 2019Guru - Experienced User
Peachyyyy wrote:
The router I'm connecting to is something with Att u-verse.-----Like I said, this is a key. If its got such a bad signal or is single band with with interference, you can have the best extender and its still going to perform poorly.
Firmare on the extender, I haven't looked at.----another key. firmware half the time gets upgraded for a reason.
the interior walls are very thin I don't know exactly.----plaster lathe, metal studs, bunch of hvac in walls, foil lined insulation, many materials block signals. Saying its a thin wall doesn't tell us anything.
It's a 3 bedroom home so not huge. Just big enough that the wifi drops to 2 bars on our side of the house.----3 bedroom house could be many different sizes. How many sq ft is the house?
Still didn't work.
My confusion is that it does connect but only for a good 2 minutes before it seems to drop the signal and the Netgear logo starts blinking.------tough to tell you without more info. Try switching it to access point mode and hardwiring it into the router. If it works fine, its probably the base router as AP mode doesn't rely on the routers wifi .
