chonchybelly
May 08, 2020Aspirant
AC1200 Range Extender - how to get rid of 5ghz band
When I set up my range extender with Negear's software there is an option to uncheck the radio button that should exclude the 5ghz band from being extended. I uncheck the button and proceed with setu...
May 09, 2020Guru - Experienced User
Is there a reason you want to deactivate 5ghz?
Even if you don't want to use it for extending, you could use it for fast lane (dedicates one band for router----extender communication). With 5ghz being faster, you'd end up with lower latency and faster speeds than just going 2.4ghz extending.
Reason why is an extender has to recieve and retransmit with the same chip, and it can't do both at once. So it cuts throughput in half and increases latency. Fastlane helps prevent that.
chonchybelly
May 18, 2020Aspirant
Thanks for the info. I'm not quite sure what you're talking about but it sounds like I don't want to get rid of it. I just thought that my router was not equipped for 5ghz, so there was no point in having it available. I guess I'm wrong? Do I need to do anythign to set up fastlane?
