CROWDS
Apr 04, 2020Follower
AC1200 Range Extender ALL LEDs Green but no internet connection
Hello and thank you for taking the time to review and help! I appreciate all advise and will try to give as much info as I can. I bought this adapter back in November during a trip to Best Buy on...
Apr 05, 2020Guru - Experienced User
I'll link to the support site with manuals, firmware, and troubleshooting. The manual walks you through a firmware update.
One thing I'd recommend, if you set it up via wps with your ISP router, is to re-do the setup using the installation wizard and not wps. Potentially the isp updated the router firmware and maybe its creating conflict with the wps setup.
