20GT
Jun 25, 2022Guide
AC1200 remove login page to get the new extender set up page
I have a used AC1200 Wi-Fi booster device. When I connect to it to set it up a login page appears and not the New Extender Setup page. How do I fix this?
- Jun 26, 2022
I followed a video on youtube and it was pretty easy from there thanks for your help
Jun 26, 2022Guru - Experienced User
What extender do you have? AC1200 is a speed, not a model.
After the reset, did you connect to the netgear_ext page?
- 20GTJun 26, 2022Guide
ex5000 thanks didnt know that about that number being speed.
after i reset it i could still connect to it but this time when i wnt to the page, the page said i wasnt connected to it.- plemansJun 26, 2022Guru - Experienced User
I know it sounds stupid but are you connected to the extender's own network and not the routers. (seen it happen).
also, if you're on ios or mac, make sure icloud relay and private mac/ip address are disabled.
yes i found the EXT network and connected to it
0
Also yesterday i came across a NTEGEAR site that allowed me to chat to a pesron and eventually gave them my phone number to get assigned a case number and a call from a tech. when he called he walked me thru some stuff and when I clicked on the ext network it said there was no IPv6 info being shared and that was the reason. he then proceeded to try to sell me service to
REMOVE INFECTIONS
REMOVE FAKE IP ADDRESS
REPAIR SERVICES
REINSTALL DRIVERS
OPTIMIZATION OF NETWORK
SECURE SOCKET LAYER CERTIFICATE (NETWORK FIRE WALL- plemansJun 26, 2022Guru - Experienced User
REMOVE INFECTIONS
REPAIR SERVICES
REINSTALL DRIVERS
SECURE SOCKET LAYER CERTIFICATE (NETWORK FIRE WALLThat wasn't netgear. They do charge for help if you're after 90 days but they don't sell you any of that. don't google for netgear support as you'll get scam/con sites.
To get a hold of support. Click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process. Keep in mind that its only free for the first 90 days.Netgear uses gearhead for support. you can go directly to them if you'd like as well.
Your page makes it seem like you already hit WPS on the extender. Did you do that?
if you log into your router, does the extender show under the attached devices list (or equivalent list)
