Tprent
Jun 02, 2025Aspirant
AC1200 Wifi Extender Can't Connect to Xfinity Gateway
Hello, I am having trouble getting my Xfinity Gateway (XB8-T) to recognize my wifi extender. Sadly, it was connecting fine with the old gateway model and I was upgraded for free and now can't get i...
- Jun 04, 2025
I ended up ordering a new Wi-Fi extender, different brand and it was simple to connect and is working great. I can only assume something crapped out with the netgear. I didn’t want to go with the pods in case I ever change network providers. Luckily it worked at half the cost of the pods
Tprent
Jun 03, 2025Aspirant
OK, I used this extender without issue on my last gateway. So I know how it’s supposed to work. For some reason as soon as I upgraded my gateway, it would not reconnect to the new one. I’m not sure if there’s different ways to try to connect it that I could try, or if there’s a setting on my gateway that I should be looking for that might be blocking it. Or if there’s a way to get it manually added as a device to my gateway.
I’m about to give up and just get a Xfinity pod. I was just trying not to spend $120
