boness
Jun 26, 2020Follower
ac1200 wifi extender ex6150
unable to join network "NETGEAR_EXE"
Jun 26, 2020Guru - Experienced User
What router are you connecting the extender to?
What firmware are you running?
What method of setup did you use? If it was wps, I'd recommend rerunning setup using the smart installation wizard.
