spankygtr
Feb 21, 2023Aspirant
AC1200 wifi extender
I inherited this extender from my sister, who passed last year. I am trying to use it, but I am prompted for the password she used, which I dont have. Can anyone tell me how to change the password? N...
Kitsap
Feb 21, 2023Master
spankygtr wrote:I inherited this extender from my sister, who passed last year. I am trying to use it, but I am prompted for the password she used, which I dont have. Can anyone tell me how to change the password? Netgear support wont tell me anything without purchasing a support package that costs more than the unit itself! Thanks in advance for your help.
You need to look more carefully at the device for a model number. AC1200 does not appear to be the model number of a Wi-Fi extender. The AC1200 is more of a marketing label. Possibly a model EX6110, could be something else.
When you get the model number, go to the downloads section above and download the manual (no charge). There should be a reset button that will allow you to start the setup process from scratch and input your own password.
spankygtr
EX6110.
I was able to use the reset button, problem now is theres no WPS button on my Spectrum router.And there is no prompt to create a new password for the extender, I see "connected, no internet", when I log on to it.
- spankygtrFeb 21, 2023Aspirant
I also got this message:
Unable to connect
An error occurred during a connection to (the dot net address I was told to go to, for some reason the forum will not let me put that in the post, very strange)
So it seems that I can connect to the extender, but its not seeing the router.
So I found out that theres no way to connect with a WPS button (there is none on my router).Is there another way to connect?
- KitsapFeb 21, 2023Master
spankygtr wrote:So I found out that theres no way to connect with a WPS button (there is none on my router).Is there another way to connect?
Go to the Downloads section above and download the Installation Guide. On page 2 of the installation guide, it gives detailed instructions for connecting to the Netgear Installation Assistant using either a computer or a mobile device over Wi-Fi.
