spankygtr
Feb 21, 2023Aspirant
AC1200 wifi extender
I inherited this extender from my sister, who passed last year. I am trying to use it, but I am prompted for the password she used, which I dont have. Can anyone tell me how to change the password? N...
spankygtr
EX6110.
I was able to use the reset button, problem now is theres no WPS button on my Spectrum router.And there is no prompt to create a new password for the extender, I see "connected, no internet", when I log on to it.
spankygtr
I also got this message:
Unable to connect
An error occurred during a connection to (the dot net address I was told to go to, for some reason the forum will not let me put that in the post, very strange)
So it seems that I can connect to the extender, but its not seeing the router.
- spankygtrFeb 21, 2023Aspirant
So I found out that theres no way to connect with a WPS button (there is none on my router).Is there another way to connect?
- KitsapFeb 21, 2023Master
spankygtr wrote:So I found out that theres no way to connect with a WPS button (there is none on my router).Is there another way to connect?
Go to the Downloads section above and download the Installation Guide. On page 2 of the installation guide, it gives detailed instructions for connecting to the Netgear Installation Assistant using either a computer or a mobile device over Wi-Fi.
thanks!
- michaelkenwardFeb 21, 2023Guru - Experienced User
The WPS button has baffled many people. They don't realise that it is there, but cunningly hidden.
You don't say what your router is (Spectrum is an ISP that provides various boxes), but Netgear's routers use a combined LED/Switch for this. (Same for the WiFI.)
It is often the one on the front that has this symbol:
WPS
Then again, maybe Spectrum has found routers with no WPS.
