JimBo5
May 24, 2020Initiate
AC1200 Wifi Range Extender Model 6110
Recently purchased the Model EX6110 and I am unable to connect to the Viasat WiFi Gateway. The Gateway supports WEP and WPA security standards. The Model EX6110 supports WPS and does not have an et...
- May 24, 2020
Maybe someone set it up prior. Plug the extender in, push and hold reset for 7-15 seconds. That should reset it back to factory. Then you can try connecting to use the assistant.
