pilsitz
Jan 24, 2023Aspirant
AC1200 WiFi Range Extender, Model EX6150
I want to use this extender in Access Point Mode. It was previously set up in Extender Mode. I did a factory reset and connected it to my router with an ethernet cable. It shows 2 networks: NETGE...
Jan 25, 2023Guru - Experienced User
Start over and factory reset it. Push and hold reset for 7-15 seconds while powered on.
Leave it disconnected from your router.
Use the installation assistant but instead of selecting extender mode during the install, use the access point mode. Once you run through setup, then wire it into your router.
How do I install my NETGEAR WiFi range extender as an access point? | Answer | NETGEAR Support
