heaucp1
Mar 17, 2018Aspirant
AC1200 Wifi Range Extender
The model pic list does not show my model which is EX6110-100UKS. This is operating but does not extend the range of my router. It has setup another connected network which is only accessed when di...
- Mar 17, 2018
Hi heaucp1,
Goto wireless settings in left page and change the name that you prefer.
jvasanth1984
Mar 17, 2018Virtuoso
Hi heaucp1,
Do you see Router LED turned ON? If so, setup went through fine. You'll be able to access extender's settings using mywifiext.net from any device which is connected to extender's network or from other devices on network using its IP address which can be located from connected devices of your router.
- heaucp1Mar 17, 2018Aspirant
Thanks but are you saying that I can configure the extender to use the same network address as my router network name (SSID)
- jvasanth1984Mar 17, 2018Virtuoso
Hi heaucp1,
By default it'll be your router's network_EXT. But if you want, you can have it modified as same.
- heaucp1Mar 17, 2018AspirantCan you tell me how to do this please. There is no place I have seen in mywifiext.net software to enable this to be done.
