whow
Sep 02, 2024Aspirant
AC1200 WiFi range Extender
Can I operate two extenders of the same router (so that I have an extender at each end of my house)?
Sep 02, 2024Guru - Experienced User
Can you? yes.
Should you? Thats another questions. If they're far enough apart, it shouldn't cause issues. But if you're setting them up in mesh mode (you don't say what extender you have), they can end up connected to each other and not back to the primary router. So it makes it a challenge. What extender model are you looking at? (hint: ac1200 is a speed, not a model)
- whowSep 03, 2024Aspirant
Thanks for your response.
The first extender is Model EX3110.
The second extender is Model EX6110
- plemansSep 04, 2024Guru - Experienced User
The EX6110 is a mesh extender, the EX3110 isn't.
You should be able to set them up. Just don't daisy chain them.
Daisy: Router----->extender------>extender
Set them up star:
star: Extender<---------router--------->extender
- whowSep 07, 2024Aspirant
thank you
