Shocker1
May 27, 2020Initiate
AC1200 WiFi Range Extender(EX6150v2)
I just installed a new range extender. Our wifi provider has a 2.4 ghz network and a 5.0 ghz network. Now I also have a 2 and 5GEXT networks.
Do I need to manually connect to the strongest network whenever I am in a different part of the house on my iPhone or laptop?
Or is there a way for my iPhone and laptop to search automatically for the best network?
- plemansGuru - Experienced Useryes, you'd need to manually change. The EX6150 isn't a mesh extender. meaning you can set the ssid the same but devices would be "sticky" meaning they'd stay connected to 1 network until they lose signal.
With a mesh device, it uses the same ssid as your router and then lets the iphone roam using its roaming protocol that the extender and the phone use.- Shocker1Initiate
Thank you for the answer!
