ccoldiron's avatar
ccoldiron
Follower
Jul 31, 2017
AC1750 / C6300 most recommended wireless extender
Hello all, our cable modem and wireless router are hooked up in our Basement - we have a very large house and so our internet cuts in and out while we are upstairs or outside.  I work from home so this is extremely important that I have the full range.  Which wireless extender will fit this model the best?  Looking to plug something in on the main floor so that it would reach both the lower basement and the upper level.  Office is on the main floor.  Thank you kindly for your help and expertise!
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello ccoldiron
    Any of the AC extenders will work it will depend on your budget and how far you want to cover.
    DarrenM
