masterj1500
Dec 26, 2022Follower
AC1750 EX6250 - Laptop Can't Connect to the Wifi Extender
Wifi Mesh Extender AC1750 EX6250 - Laptop Can't Connect to the Wifi Extender It can connect to our internet but when I plug in the extender it just says, "connected, no internet." I've update...
- Dec 27, 2022
Did you set it up using the push button WPS option?
If so, factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
Dec 27, 2022Guru - Experienced User
