Brightonfireman
May 29, 2020Follower
AC1750 extender fails to find ip address???
Cannot set up and extender says the device fails to locate IP address?? How do I deal with this?
1 Reply
What router are you connecting to?
Firmware on the extender?
did you run setup using the wps method or the installation wizard. I highly recommend using the installation wizard.
