MurrayF
Jan 18, 2021Guide
AC1750 Mesh Extender and Telstra Smart Modem
Hi Based in Australia and have just received our new Telstra Smart Modem but I am having no luck trying to connect my AC1750 WI FI Mesh extender. Extender worked perfectly with the previous modem...
Jan 19, 2021Guru - Experienced User
What telstra smart modem is it?
Are you setting up using wps?
If so, I'd try setting it up using the installation assistant.
For best results, factory reset the extender (push and hold reset for 7-15 seconds while powered on), then connect a pc/laptop to the ethernet port and disable the pc/laptops wifi so it only uses the ethernet connection, then try setup using the assistant.
