MurrayF
Jan 18, 2021Guide
AC1750 Mesh Extender and Telstra Smart Modem
Hi Based in Australia and have just received our new Telstra Smart Modem but I am having no luck trying to connect my AC1750 WI FI Mesh extender. Extender worked perfectly with the previous modem...
MurrayF
Jan 20, 2021Guide
Thank you for your help.
I will give it a try tonight and let you know how I get on.
Murrayf
MurrayF
Jan 26, 2021Guide
Apologies for the late reply - wanted to let you know that your solution worked.
Thanks for your help.
Murrayf
- plemansJan 26, 2021Guru - Experienced User
glad it worked!
- MurrayFApr 11, 2021Guide
Hi
Are there any tips or tricks if we want to have mote than one mesh extender in the house? I bought one but had no luck getting it connected.
- plemansApr 11, 2021Guru - Experienced User
are you daisy chaining?
daisy chain: router----->extender------>extender
or setting up as a star configuration
star: extender<------router------>extender
I'd recommend star.
Tip for help setting up is shut off the 1st extender that is already setup.
