MurrayF
Jan 18, 2021Guide
AC1750 Mesh Extender and Telstra Smart Modem
Hi Based in Australia and have just received our new Telstra Smart Modem but I am having no luck trying to connect my AC1750 WI FI Mesh extender. Extender worked perfectly with the previous modem...
Jan 26, 2021Guru - Experienced User
glad it worked!
MurrayF
Apr 11, 2021Guide
Hi
Are there any tips or tricks if we want to have mote than one mesh extender in the house? I bought one but had no luck getting it connected.
- plemansApr 11, 2021Guru - Experienced User
are you daisy chaining?
daisy chain: router----->extender------>extender
or setting up as a star configuration
star: extender<------router------>extender
I'd recommend star.
Tip for help setting up is shut off the 1st extender that is already setup.
- MurrayFApr 11, 2021Guide
Fairly sure i am doing the star as I am trying to connect to the telstra modem direct.
The extender does not seem to recognize the modem at all.
Should I try connecting the extender to a laptop and connecting that way?.
Its always worth trying setup that route
Is that way more reliable?
- plemansApr 12, 2021Guru - Experienced User
Tends to go faster and smoother than trying to use an app. And I trust it more than wps as wps doesn't always get coded as it should
