Ibbsy
Nov 17, 2020Follower
AC1750 wifi extender
Hi - our extender has been dropping out daily. We’ve reset it so many times and now cannot connect to the unit using mywifi.local, it doesn’t appear to find it.
Our internet is fine. We moved the extender to the same room as the router and still not working. This has happened a number of times before but not this bad. Unfortunately the warranty expired last month. Why is this happening and what’s needed to rectify this please?
Thanks
Thanks
1 Reply
What firmware is on the EX6250?
What router is it connected to?
Did you set it up using wps or using the installation assistant?
