papistemp
Jan 06, 2023Guide
AC1750 WiFi Mesh Extender (EX6250) - Connected but no internet (only on channel 2.4 Ghz)
Hello, I have the AC1750 (EX6250) repeater which was working fine until yesterday, and for some reason I don't yet know, the 2.4Ghz wifi network stopped having internet. It is clearly visible on the...
papistemp
Jan 06, 2023Guide
Hello plemans
my extender is connected to --> Nighthawk AX6000 AX8 8-Stream WiFi Router (RAX80)
I did not use WPS for the setup, i used the NightHawk Android Application.
I've, in the past, already done some factory resets & setups without issues.
Jan 06, 2023Guru - Experienced User
Make sure you're not using wpa3 on the router.
Try the installation assistant and not the app
- papistempJan 06, 2023Guide
i'm not using WPA3 but WPA2-PSK [AES]
i just did the factory reset again, ... and only the 5Ghz channel is working 😕 with internet
How come such a thing happens suddenly ? ... how can i check whether or not it's related to the latest firmware update ... i see there a recent one, and my extender has the latest firmware, maybe something went wrong .... it's really annoying !
I'm blocked for many things (for devices not supporting 5Ghz 😞 ....
Is it possible to downgrade ?
- plemansJan 06, 2023Guru - Experienced User
You can downgrade the firmware. Just use the manual update process but instead of using the latest, you use the older version.
it looks like its setup properly according to your photo.
Are you using any special characters or spaces in the ssid/password? if so, try removing them
no, i am using only alphanumeric chars 😕
By any chance, do you have the link for old firmwares ... i'm still not able to find the location
