papistemp
Jan 06, 2023Guide
AC1750 WiFi Mesh Extender (EX6250) - Connected but no internet (only on channel 2.4 Ghz)
Hello, I have the AC1750 (EX6250) repeater which was working fine until yesterday, and for some reason I don't yet know, the 2.4Ghz wifi network stopped having internet. It is clearly visible on the...
papistemp
Jan 06, 2023Guide
Thanks, i just noticed that this wifi extender is WIFI-4 while my router is WIFI-6, that's a pity !
what would you advice my as a dual wifi wifi extender mesh ? i see this with a kind of fair price : WiFi 6 Mesh Orbi (RBK352)
And btw, still not working ... even after downgrade, factory reset and reconfiguration ! .... amazing 🙂
Jan 06, 2023Guru - Experienced User
Try downgrading the firmware on the router a version and factory resetting it before buying something new.
i've seen a few posts with issues on the RAX43/45
- papistempJan 06, 2023Guide
still not working
Btw, do you know whether or not the Mesh Orbi (RBK352) are both extenders or (one one them is a router, and the other one an extender ?)
- plemansJan 06, 2023Guru - Experienced User
One is a router and the other an extender.
for AX extenders, there's the EAX line of extenders.
