Bartfai
Jan 27, 2022Initiate
AC1800, my extender works while hard wired, but cannot go wireless as it drops connection
My extender works hard wired, but cannot get it to go wireless
Jan 27, 2022Guru - Experienced User
What happens?
What router is it connected to?
What model extender do you have? AC1800 isn't a model its a speed and i think you mean AX1800 at that.
What firmware is on the extender?
What method of setup did you use? WPS, the installation assistant, or the app?
