marc74
Jun 17, 2020Aspirant
AC1900 cannot access webpage
so it was installed and working fine but then i discopnnectedc to test an issue with biffering elsewhere. wasnt this device so i connected back up. now i can never connect to the mywifiext webpa...
marc74
Jun 18, 2020Aspirant
do we have no netgear support here? cant get a reply on twitter.
im dead in the water about to send the device back when i thought was working fine
- plemansJun 18, 2020Guru - Experienced User
What extender are you using? You didn't put a model. AC1900 is a speed.
What firmware is on it?
What router are you connecting it to?
Did you set it up via wps or the installation wizard?
- marc74Jun 18, 2020Aspirant
it is a netgear ac1900 wifi mesh extender.
model ex6410
i had all working connected to router, moved location and still working and could login to the website and disable 5G etc.
but when we had buffering when watching a film i decided to test if this was causing interference... it didnt so i replugged it in.
I have reset it and can connect to the router over wps
the extender has the light on to show im connected to it..
i just cannot get access to it on any website.
I belueve it has defaulted to 5G connection and as said i am connected to it but i cannot use the site to disable the 5G and check connection etc.
my next option was maybe to switch off the router for some time.. maybe its IP address related etc?
ty
- marc74Jun 19, 2020Aspirant
so no support and the help pages just ask to pay for support
this should not be hard to reset when i had it working
