marc74
Jun 17, 2020Aspirant
AC1900 cannot access webpage
so it was installed and working fine but then i discopnnectedc to test an issue with biffering elsewhere. wasnt this device so i connected back up. now i can never connect to the mywifiext webpa...
Jun 19, 2020Guru - Experienced User
Try setting it up via the installation wizard. Not using wps.
Support is only free for the first 90 days from purchase. And to use it you click mynetgear, register an account, and then the device. From there you can contact support.
marc74
Jun 19, 2020Aspirant
ok well its new so i will but still...
