carmelahollin
Sep 21, 2022Follower
AC1900 Dual Band WiFi Mesh Extender - model #: EX6400
I cannot get the wifi extender connected. I got it connected to my router but there is no option on devices to connect them to the wifi extender.
Sep 21, 2022Guru - Experienced User
1. what router did you connect it to?
2. what firmware is on it?
3. the EX6400 is a mesh extender. It uses the same ssid/password as the router so it won't show up as a different network. It allows your devices to roam between it and the router as needed. You can disable this function if you want.
