Jerrytr5
Oct 23, 2022Tutor
AC1900 EX6410 mesh extender not connecting to internet
Purchased a couple of these extenders to add to my old D6400 wifi network which works fine but there are a couple of dead spots around the house. Went through the setup procedure for each as instruc...
Jerrytr5
Oct 23, 2022Tutor
Router is a Netgear D6400.
The extenders are wireless.
Reset the extenders to factory setup, downloaded the Nighthawk app for initial setup (which I did initially, but started from scratch again).
Logged on to the extender via browser for more options.
Now using a single extender on the 2.4ghz frequency only which appears to be working.
What other options might work better for me?
Thanks for the help.
Jerry
Oct 24, 2022Guru - Experienced User
Is your D6400 connected to DSL?
Or are you using it in just router mode?
I'm a fan of mesh systems like Orbi. And you can find a bunch of renewed orbi's on amazon right now. If you're not needing the fastest AX speeds, the RBK43 system is pretty solid and provides you 2 satellites.
- Jerrytr5Oct 24, 2022Tutor
Not entirely sure I understand the question. I am using the D6400 as my primary wifi router connected to my broadband supplier.
Anyway, problem solved. The Netgear extender products are going back and I have replaced them with a TP-link tl-wa850re which appears to do the same job for a third of the price and took 10 mins to set up.
In order to get full seamless wifi coverage my conclusion is that I will need to replace my current devices with a mesh system - attempting to enlarge an old network just isn't practical.
Thanks for attempting to help.
Jerry
- plemansOct 25, 2022Guru - Experienced User
Just be advised that that tplink extender is a pretty base model N300 device. It isn't going to have much speed/performance. There's a reason its a 3rd the price.
