JimmyRoberts444
Mar 03, 2019Aspirant
AC1900 Range Extender No connection following firmware update
AC1900 Range Extender No connection following Firmware update
Just purchased at BestBuy, set up extender and all worked. (I use network cable conn from extender to computer)
Then I noticed a...
JimmyRoberts444
Mar 11, 2019Aspirant
Thank you...
I have performed the reset. After that I can successfully connect to the extender again, and can go through the set up again. But upon completion, it then repeats the issue-- I suddenly lose connection to the extender via my network cable. Wifi does set up and work, but my network cable connection is gone at that point. And I need it (i don't use wifi on this computer)
I brought my other EX7000 to this PC (already setup for over a year) and the network cable connections work fine as is. Again, I'm using the network cable to setup the Extender, and then afterwards... there is no network connection via the cable.
Christian_R
Mar 11, 2019NETGEAR Employee Retired
Hi JimmyRoberts444,
Couple things:
1. Is the extender located in your preferred location?
2. When there is no network connection, what is connected to the extender and how? (via wired/wifi)
3. May you provide your network topology
~Christian
