Gary3935
Aug 11, 2021Tutor
AC1900 refusing some connections
Yesterday my AC1900 WiFi extender started refusing connections to some devices on the 2.4GHz band. I can connect a couple Chromebooks but other devices (cell phones, Wyze cameras, and iPads) will no ...
michaelkenward
Aug 12, 2021Guru - Experienced User
Gary3935 wrote:
I can connect a couple Chromebooks but other devices (cell phones, Wyze cameras, and iPads) will no longer connect at 2.4GHz.
When some devices work while others don't, my first move is to look at the wifi clients rather than the wifi source.
Tried getting the refuseniks to forget the connection and rejoining the wifi?
Gary3935 wrote:
I updated the router's firmware and cycled power on all devices.
Before or after this happened?
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
WiFi Range Extenders & Nighthawk Mesh - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
Gary3935
Aug 12, 2021Tutor
Everything has been working fine on the 2.4GHz band for several years now. It just started refusing connections a couple days ago for connection attempts from about half of my devices that have been connection just fine for years.
After several of my devices would no longer connect on the 2.4GHz band I updated the firmware in the router. No change, some devices will connect, others will not connect.
Disabled the 5GHz band on the router. No change.
On the router setup page there is no ability to reduce the number of clients so I should get 16 on each band. This limit was never reached, just some devices no longer connect at 2.4GHz.
Looks like I have to buy a new WiFi extender.
- plemansAug 12, 2021Guru - Experienced User
well, you didn't answer any of the questions asked.
- Gary3935Aug 12, 2021Tutor
The router is connected via WiFi to a router supplied by CenturyLink using the 2.4GHz band. This connection is working fine since I can connect to the Netgear extender using either band EXCEPT on those devices that are now failing to connect via 2.4GHz.
The Netgear was setup so long ago I don't recall what method was used. However, the setup was successful, has been working correctly for years until a couple days ago.
The devices that won't connect to the Netgear via 2.4GHz can connect to the CenturyLink on it's 2.4GHz band.
This failure to connect issue with some previously connecting devices just started a couple days ago. Had been working fine for years.
What centurylink router is it?
2.4ghz is sensitive to interference. Have you tried changing the channel the router broadcasts on?
What firmware is on the extender?
Did you try factory resetting the extender and reinstalling it using the installation assistant?
