sengeb52
Feb 04, 2026Aspirant
AC1900 Wifi Extender help
I have tried many, many factory resets, I have unplugged and plugged the extender, I have moved outlets, I have moved rooms with the extender and I cannot fix my issue. If I plug in the extender ...
CrimpOn
Feb 04, 2026Guru - Experienced User
If the power LED flashes amber and there is no WiFi signal named NETGEAR_EXT, this extender appears to be dead. If purchased from an authorized reseller within the last year, it should be eligible for a warranty replacement. If purchased recently, I would return it to the retailer.
