Bslobo
Mar 27, 2019Aspirant
Ac1900 WiFi extender
purchased the unit. I need to mount to the wall. The unit I had was a dlink 655 router.
Does anyone one have any suggestions on mounting to the wall? It has no holes for the mounting screws. ...
Mar 28, 2019Guru - Experienced User
Build a small wooden shelf on the wall where the R7000 needs to be placed?
Bslobo
Mar 28, 2019Aspirant
Thx I looked on Amazon and got a wall mount bracket. It slides into the bracket. WIll let you know Thank you for the response.
- FURRYe38Mar 28, 2019Guru - Experienced User
Good place to check. I know Amazon has brackets for the Orbi system. Didn't know if they had one for the EX. Let us know how it turns out.
