maxx1010
Jun 24, 2020Aspirant
AC1900 wifi mesh extender EX6400
so I just connected this I am not sure how I feel about it. On my iphone it use to suggest 2.4 GHZ or 5GHZ for my wifi to connect to. now it is only showing 5ghz 2.4 doesn't show as an option. and I ...
Jun 24, 2020Guru - Experienced User
Are you running it in mesh mode?
If so, it uses the same ssid for both and then can switch a device from 2.4ghz to 5ghz as needed.
- maxx1010Jun 24, 2020Aspirant
I don't know if in mesh mode how can I tell?
- plemansJun 24, 2020Guru - Experienced User
Log into it and check if its using the one ssid/mesh function.
you can get the manual by going to netgear.com/support/ type in the model number and it'll bring you to the manual, firmware.
there are 2 2.4 and 5 ghz is that correct?
