maxx1010
Jun 24, 2020Aspirant
AC1900 wifi mesh extender EX6400
so I just connected this I am not sure how I feel about it. On my iphone it use to suggest 2.4 GHZ or 5GHZ for my wifi to connect to. now it is only showing 5ghz 2.4 doesn't show as an option. and I ...
maxx1010
I don't know if in mesh mode how can I tell?
Jun 24, 2020Guru - Experienced User
Log into it and check if its using the one ssid/mesh function.
you can get the manual by going to netgear.com/support/ type in the model number and it'll bring you to the manual, firmware.
