Boggles35
Aug 07, 2021Follower
AC1900 Wifi Mesh Extender Router password not connecting
I'm trying to connect my extender to my router. I've selected the appropriate router then enter my password. it's saying my password is incorrect. I know the password is correct. What am I doing ...
Aug 07, 2021Guru - Experienced User
What router are you connecting it to?
What firmware is on the extender?
did you try setting it up using wps and not using the installation assistant?
