Bigglesworth1's avatar
Sep 21, 2022
AC1900 WiFi Mesh extender
Can anyone tell me what the router link LED means as it is sometimes green and sometimes red.
Thanks
  • On wifi extenders, the router link led indicates the connection quality to the router.
    There's a couple different "best connection" colors based on the model. Not sure what model you have. But its roughly this:
    • Solid white/blue/green. Best connection.
    • Solid amber. Good connection.
    • Solid red. Poor connection.
    • Off. No connection.
  • FURRYe38's avatar
    What model unit do you have? AC1900 is a wifi speed.
  • plemans's avatar
