kamkam123
Jun 13, 2024Aspirant
AC1900 WiFi Range Extender 2.4g work but 5g says no connection
So, i have the extender setup and 2.4g is connecting to the internet but 5g says no connection. I was on the latest firmware 1.0.1.112 but reverted back to an older version with no success. Any idea...
- Jun 13, 2024
that "no connection" you see on the status page? That means there isn't a device (phone/tablet, etc) connected to the extenders 5ghz.
schumaku
Jun 13, 2024Guru - Experienced User
What is the ide reverting to an older firmware version please? Re-introducing security vulnerabilities or loosing the ability to use the simple basic https support added on .112?
kamkam123 wrote:
Any ideas why I can use 2.4 but not 5g???
Probably the 5 GHz band was not configured properly, or the existing WiFi router handling the 5 GHz band config was changed?
kamkam123 wrote:
Next steps?
As usual here, factory reset the EX7000 to the default config, and reconfigure the unknown to us connections to the primary Wi-Fi router from scratch again. Consult the fine documentation FMI.
