kamkam123
Jun 13, 2024Aspirant
AC1900 WiFi Range Extender 2.4g work but 5g says no connection
So, i have the extender setup and 2.4g is connecting to the internet but 5g says no connection. I was on the latest firmware 1.0.1.112 but reverted back to an older version with no success. Any idea...
- Jun 13, 2024
that "no connection" you see on the status page? That means there isn't a device (phone/tablet, etc) connected to the extenders 5ghz.
Jun 13, 2024Guru - Experienced User
that is the extender. but what router is it connected to?
Got a screensnip of the extender status page from the GUI?
kamkam123
Here is the status from the extender status page
Let me know if any other info would be helpful
Thanks
- plemansJun 13, 2024Guru - Experienced User
- kamkam123Jun 13, 2024Aspirant
Thanks I see your point. I can connect to the 5g from the basement maybe because it's farther away from the router?
But I can't connect to the extender by choice when I am upstairs closer to the router. Not sure I understand it all but it works for those devices farther away
