Jdrjsrjdshy
Mar 20, 2021Tutor
AC2000 as a WiFi extender?
Hi so I have bought a AC2000 mistakenly thinking an wireless access point would extend my existing WiFi network, is there a way I can configure it to do this? rather than having 2 separate Wi...
Mar 20, 2021Guru - Experienced User
What device do you have?
AC2200 is a speed and not a model number.
- JdrjsrjdshyMar 20, 2021Tutor
plemans wrote:What device do you have?
Sorry it's a wac124-100uks
- plemansMar 20, 2021Guru - Experienced User
It looks like it has router mode and access point mode.
I'm not seeing any extender mode.
You could set it up as an access point and connect it via ethernet, using a moca adapter, or even a powerline adapter.
Thanks for reply,
yes I have it set as access point via Ethernet, but would like all to be one network and the access point act as a extension to the existing network if that is possible
