K9cop1142
Dec 20, 2020Aspirant
AC2200 nighthawk extender.
Ac2200 is setup if power is disconnected will I have to go back to setup and find and install the extender again, asking in case I want to move extender .
- Dec 20, 2020
its actually done by the router. The extender has to use the same channel the router is on so changing the wireless channel, changes which one the extender uses.
What extender is it? AC2200 is a speed.
What firmware is on it?
Waht router is it connecting to?
Dec 20, 2020Guru - Experienced User
if you unplug it and plug it in elsewhere, it should retain its settings and be able to autoconnect.
K9cop1142
Hmm,it did not seem to do that for me but I will try it again ,is there anything in the settings to check for auto connect.
- plemansDec 20, 2020Guru - Experienced User
auto connect back to the router or the devices to the extender?
Reason I ask that is if you move it somewhere where the service is sketchy, something is blocking wifi (think things in walls like hvac), or its just out of range, then it won't/can't connect.
- K9cop1142Dec 20, 2020Aspirant
I was having a problem with it connecting back to router, is thgere a way to change channels on the extender so to get which ever is better or is that done by extender.
- K9cop1142Dec 21, 2020Aspirant
which firmware is better and is there installation steps now that I cannot access via phone
- plemansDec 21, 2020Guru - Experienced User
the .206 has been more reliable from what I've seen on the forums.
The support site has the manual that goes over the install process.
